I replaced the fuse behind the control panel
Some units also have a thermal fuse in line. Usually above the oven cavity. Look at your wiring schematic and see if it shows one, test for continuity and replace if bad. Also check to see if your main power comes in through your door interlock switches. Test each one for continuity with the door open and closed and replace if bad. If this is not it, you probably have a bad control board and it is usually not worth repairing. With Microwave Ovens we want to make sure your are careful. Even with the power off you can get shocked by the capacitor. Never work on a microwave oven with the power on. Very Dangerous Good Luck, Appliance Specialists.
