Here are instructions for a solution to your Coby 610 MP3 player acting up.
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the zipfile from the Coby Website will give you a PDF file with instructions, and a program file to run.
Your
music will be erased when you run this firmware update. The
instructions suggest that even if your mp3 player won't startup
properly, if you plug it into your computer you should be able to
access it as a removable disk, and copy all your music to a temporary
folder on your computer.
Here are the steps:
my coby mp 610 turned of apparently while i was - 1e93cf1.jpgsrc="/uploads/images/1e93cf1.jpg" alt="1e93cf1.jpg" class="h_mi" />
You can refer to this Coby 610 solution here.
I hope that helps.
