Spinmaster Air Hogs RC Reflex Micro Helicopter Logo
Posted on Jan 03, 2010
Heli spins counter clockwise
We have tried using the trim guide and it is not working. The first day we had it out of the box it was not a problem. Now when we try to trim it we do not get any results.
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Mar 10, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
5234
Points
20
See solution 2 for post "How do i fly my spin master air hog rc helicopter?"
  • Anonymous Mar 10, 2010
    Mar 10, 2010- Don't know if you ever solved this issue but if the problem is still there and you feel adventerous you can try to fix it.If the top rotor and shaft came loose, (either it pulls out or if you turn the upper rotor and it does not engage and turn the lower one at the same rate) I used an exacto knife to cut along the seam of mine,(you have to be careful especially in the tail section as the antenna wire runs along its length). You will have to caerfully bend up the directional fans to remove each side of the body once separated. Use a small jewelers screwdriver to open the motor housing - there is a screw on the vertical rotor housing section right behind the circut board that you will have to get to by going in on an angle - being careful not to lose the small washer on the shaft above the lower gear. Remove the upper rotor and shaft and the gear and washer. Clean all with rubbing alcohol. Now here is the hard part - place the gear back into the lower half of the motor housing, insert the upper rotor shaft into the gear until it bottoms out and mark the shaft at the top of the gear, (a dab of liquid white-out used for typing errors works well becuse it dries fast). Once dry remove the shaft and pull the gear off of it. Measure from the bottom of the shaft to the white mark and write it down - you can use a piece of paper as a guide by lining up one edge with the bottom of the shaft and placing a mark at the spot of the white out if using a ruler is too difficult to read. clean any grease off of the shaft and inside of the gear. Since the shaft is carbon fiber and the gear is polyethylene plastic not many glues work well. I used "J-B weld" a two part epoxy that is tough as nails and holds up well. place a mark on the paper guide approximately 1/64th of an inch above the original mark. This is how far you will have to place the gear from the end of the shaft, (this allows for less friction and keeps the lower gear from rubbing on the bottom of the gearbox...VERY IMPORTANT!!! insert the upper rotor shaft into the shaft housing in the top part of the gear box and place the small washer on it. Use the paper guide you made and put a small dab of white-out on the shaft using the new mark a your point of reference, (rember it's 1/64" above the original mark). Mix up a tiny amount of JB weld and put a thin coat on the shaft just below the mark. Slide the gear onto the shaft up to the mark and set aside overnight to harden. Next day reassemble the gearbox, (if you placed the gear too high up on the shaft the two halves of the gear box will not come together. DO NOT force it. use a file to take alittle off of the end of the shaft until the gearbox seats together tightly and reinstall assembly into the heli. I would tape the two halves together with scotch tape until you know you got it right. Try the heli using the trim wheel to stop rotation. If better but still not right check the flex on the rotor blades as it seems if used alot they get soft and flex too much which makes it hard to adjust. If they do flex alot try coating each with a THIN layer of JB weld to stiffen them up. This is a very delicate procedure as if you put too much on the balance will be shot. Seems like alot of messing around for a $40.00 toy but I enjoyed the challenge and it is rewarding to solve a problem and win.
1helpful
2answers
Helicopter spins uncontrollably. Will not gain left.
bent shaft maybe? are the cogs engaging properly for both sets of blades? also check your trims are centred on your transmitter before you turn it on (if it has trims)
it looks like an infra-red controlled coaxial heli, but is hard to diagnose without knowing what it is. from what i can see, the top set of blades is spinning ok, but the bottom (counter-rotating) set doesn't appear to be getting as much power,
Mar 30, 2013 • Toys
1helpful
How to correct trimming problems did what the insteuctions said and keep having the same spinning counterclockwise problem
Just bought the air hogs helicopter with the crane. Had the aircraft constantly spinning clockwise, no matter how much I turned the trim control counter clockwise the aircraft still rotated. I then turned the trim control in the opposite direction until I noticed the aircraft had stopped spinning, and used the rudder control to fine tune forward flight. So, get the aircraft to hover and turn the trim button in the opposite direction until you see that the aircraft spinning slows right down. If you continue to turn the trim control in the same direction the aircraft will increase its spin, so just dial back the trim.
7helpful
MY PROPEL RC EXECUHELI WILL NOT TRIM OR STEER. IT JUST GOES UP AND DOWN AND THE HELI SPINS COUNTER CLOCKWISE
counter clockwise would be the nose tuning to the left. My sons did this and pressing the right trim button on the controler repeatedly untill it slows is all I had to do. If you go to far it will spin int the oposite direction then you have to trim to the left and find the happy middle
Dec 26, 2010 • Toys
My son's helicopter just spins around and won't lift up anymore. It has been sitting for about a month, but worked fine before that. Any solutions? Could the blades have been bent? They don't look like...
replace batteries with new ones and then you let it spin while you trim it out by pushing rotor button ,for heli that spins clockwise push trim button on left side and a heli that spins counter clockwise push trim button on right side continue pushing the corrective button until spining slows and eventually your sons heli will fly straight again these instructions are in the owners manual
2helpful
2answers
How do i fly my spin master air hog rc helicopter all it does is go in circles
If you trimmed your heli but it still can't work, try using the direction knob to trim it instead. When it goes clockwise push th knob leftwards and hold, and vise versa for anti-clockwise. Or, push and release repeatedly in the direction mentioned till it flies straight. Tested on around 6 air hogs helis and works each time. If you still can't trim you might try it after turning it off or contact the service centre.
3helpful
Spins out of control wont trim out
Have you tried checking the back tail? It comes down right under the rotor. If it is ripped, DONT TAPE IT! Taping will just ruin the weight balance and ruin it. If it is ripped, return it and exchange it, dont try and fix it.
Lama v3 spins counter clockwise with no lift off
WOW! I have experienced the same spinning action . . all new parts etc. I have repaired 6 Coco's but this one has ate my lunch . . . when you power up it spins to the left . . . the more throttle the faster it spins . . have changed the 4 and 1 also and adjusted . . . over and over . . . does the 4 in 1 control the rudder action?
Heli wont trimm just flyies in circles counter-clockwise
Try to tap the trim button L/R instead of holding it. Worked for me.
32helpful
10answers
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 • Toys
Top Spinmaster Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Spinmaster Toy Expert? Answer questions, earn points and help others
