Can you describe in more detail what you are trying to do, step by step, and how the process is failing?
I have uploaded and downloaded pictures from my micro-SD card, both while it is in the phone, using a USB cable and setting the phone to "Menu | Settings & Tools | Tools | USB Mass Storage". Then the phone and the micro-SD card appear on my (Windows) computer as a removable drive, and I can just copy files in either direction.
I am also able to remove the micro-SD card, and plug it into an SD-card slot on my computer (with a micro-to-SD card adapter), and it mounts as a removable drive that way, too.
Note: if you have the micro-SD card in the phone, and you want the pictures you take to be stored on there so you can download them in one of the ways I've described above, then be sure to go into "Menu | Settings & Tools | 9. Memory | 1. Save Options | 1. Pictures" and set this option to "Card Memory", or else your pictures will get saved in the camera internal memory, and not on the card. This may be your problem if you are not seeing the pictures you expect on your memory card when you look for them. If you take Videos and/or Sounds, you might want to set those "Save Option" to the Card Memory, too.
