My mptv68a tv locked (don't know if it's child lock)
One day I turned on the tv (it seemed to be working fine). I changed the channel once and this happened:
1) The screen turned blue
2) The blue screen had a little red padlock on it.
and from then onwards no button except for the on and off buttons worked on both the tv and the remote.My tv is . Please help me.
I have the same problem, what adds to my problem is that the TV is branded "Universal" which creates a problem when I do a search for Universal TV on the internet. I will look more closely at mine over the weekend to see if there is a product code on the back. Thanks PaulI have the same problem, what adds to my problem is that the TV is branded "Universal" which creates a problem when I do a search for Universal TV on the internet. I will look more closely at mine over the weekend to see if there is a product code on the back. Thanks Paul
Hi. I was watching a dvd last night when for no apparent reason my tv sreen turned blue and is displaying a red padlock. It's a magnavox 68cm mptv68a. i can only turn it on and off. Need help! Cheers.Hi. I was watching a dvd last night when for no apparent reason my tv sreen turned blue and is displaying a red padlock. It's a magnavox 68cm mptv68a. i can only turn it on and off. Need help! Cheers.
Last night I turned on the tv . I changed the channel once and this happened:
You can't post conmments that contain an email address.
Omni TVs have a child lock that allows parents to prevent children
from watching specific channels or television shows with certain ratings. To
activate or deactivate the controls, you need the four digit pass code. If you
forget the pass code or if the lock gets set accidentally, you can still unlock
the TV. • Use the original
Omni remote control to turn on the TV. You need the original remote to bypass
the child lock. A universal remote won't work. Check the screen. If you see a blank screen with a red key on it,
press the "Function" and "Mute" buttons at the same time.
This unlocks only the channel that is on the TV. All the other channels will
remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by
entering "6688," which is the factory reset code. This code resets
the TV to original factory settings. Once this is done, you will have to go
through the initial setup.
• Call Omni technical support at (416)
260-0047. A technician can help you troubleshoot the television as the problem
may not be the child lock. You'll need to know the model number and serial
number of the TV. •Take your television to a TV repair shop if you
are still unable to unlock the TV. The problem may be with the wiring, so the
repairman may have to rewire the TV
If this is happening on all the channels I think you will need a total reset. If so open menu and check the settings for child lock when you manually tune. An option is to reset the channels once again after the lock is opened. Choose a new channel scan to reset the memory. However if the lock seems to be only on specified channels you can open the settings of the channel and unlock on the menu.
My child lost the tv remote and we have the child lock on so we can;t change the channel or the volume. Do you know how to turn it off without the remote?
This function will block out the picture and sound of the selected channel or video input.
It can also be used to keep the TV from being viewed for a scheduled time period that you set.
The code to enter the Locks feature is a four digit secret code number. The factory preset code is 0000.
Use the number buttons to select access code.
Use CURSOR G or H to highlight function and then press the SELECT button.
To change the access code number, select Change Access Code. Enter a new four digit key number you prefer.
Select CHANGE ACCESS CODE to change factory preset code (0000) to your preference.
When ENGAGE LOCK is selected, SET CHANNEL LOCK, SET INPUT LOCK, and SET FRONT PANEL LOCK can be set individually.
When SET CHANNEL LOCK is turned on, the picture and sound for the chosen channel will be blocked out.
When SET INPUT LOCK is turned on, the picture and sound for all video inputs and the picture and sound for channels 3, 4 will be
blocked out.
When FRONT PANEL LOCK is turned on, all buttons on the Front Panel will be deactivated, except the Power button.
When TV TIME LOCK is turned on (r TIME LOCK) you can set the BEGIN and END times (CURSOR E) and the TV
cannot be viewed during that time period (Set clock first). Use CURSOR G or H to highlight ONCE (TV will time out one time
only), DAILY (TV will time out every day), WEEKLY - SUN~WEEKLY - MON (TV will time out one time a week) or OFF (to disable
this function).
When MOVIE RATINGS is selected, you can block various types of movies and video tapes based on motion picture ratings. Picturein-
Picture will also be blocked automatically (see page 45).
When TV RATINGS is selected, various types of television programming based on a parental guide ratings will be blocked.
Picture-in-Picture will also be blocked automatically
If you forget your secret code, use the factory code 7777 to erase your key number. This will reset the secret code number back to the
factory preset 0000.
Press EXIT to quit the menu.
any magnavox controler will work just put in some good batteries . lots retail wholesale stores like walmart carries magnavox tv remotes but make sure its a magnavox.
Go to the channel where Child Lock is ON
Press " --- " Key ( below channel 9 button) for few seconds,
Child Lock will be OFF
Press again Tune Lock will be OFF.
Hello pea16 serrure enfants means lock infants or as we say child lock.
Hold the display button down for 10 seconds, which removes the lock.
If that does not work try: unplugging the TV for about five minutes and see if that clears it, If you need the owner's manual you can goto: http://www.magnavox.com/ then click on support center and enter your model number.
Then go to the language section and select english.
I know one code please try if it helps
1 press mute button once on remote control handset.
2 once again press &HOLD remote hand set mute button.
3 while keeping mute button pressed press menu button on tv set.
good luck
