If it is not a loose connection (internally), it may be most probably related to your picture tube. Check it out and if found faulty get it replaced. If your are in any warranty period (I don't think so since it is 3-5 years old), don't do anything and just inform them, or else you will loose your warranty security.
well it looks to me u need a new tv....all the details u give are pointing that ur picture tube is gone.....but call LG help and costumer line and ask them......u may get away from it to get a new tv make sure when u get a new plasma to extend ur warren tie to a max o 3 to 5 years and if this would happend u get it repaires for free.......cost for a new screen app 1000 to 1500 dollars
Here's the number to HP case management 877-917-4380 ext.79, try this
number and be firm that they need to fix this, I just had an HP plasma
that was 3 yrs old replaced for free, no charge. Good luck
There is not much you can do to fix your plasma. Since the plasma is less then 1 year old, still under Samsung warranty.
I would suggest to call them to fix it.
Good luck.
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it. Good Luck.
