Expert
- Posted on Jan 03, 2010
Re: My vacuum cleaner is giving off a burning smell.
If its a rubber burning smell check the belt and the brushroll. if its an electrical burning smell then dont use it. the motor is overheating and will eventually get hot enough to catch fire.
this burning smell ? may be the drivebelt is spinning on the motor shaft normally caused by the roller brush and the vacuum dicts that are blocked you need to check bag is not full? then turn vac over to access the cover plate of the roller brush assy you should be able to remove this cover if you look at how it secures ? screws? when you remove cover you can then lift out the roller brush and lift off belt any restriction /blockage will be apparent now?? clear them and the brush then reassemble is reverse of above as you do not say what smell is like ie rubber? over heated motor ? the above is probably cause ? if you have any more info ? or req help then come back with info?? hope this helps ?
