Our washer stops mid cycle on all cycles and flashes the start and Superwash lights 5 times, then goes off and repeats the same sequence. Typically stops indicating that there are 30 mins left. This also happens if start a drain or spin. Often have to switch off for a few mins, then start drain and hope will start. Have checked drain pipes and can hear pump go when it does start. Anybody with any ideas.
Thanks for the information Courtdate, I will try this out.
Hi I have the same problem but my machine is a hoover hswf 167 and the lights flash 5 times
I have Whirlpool washer and I have the same problem.Replaced timer and it continued to stop in mid cycle.I removed water pump and check for something caught inside of it but no luck.Any other suggestions??
goes on hold mid cycle with the start and delay start LED flashing 3 times
Hi - Washer stopped in mid programme - now has no sign of life at all. Have checked main switch on the front & it switches the supply to the main board. Any ideas? Thanks
