Refrigerators Logo
Anonymous Posted on Jan 02, 2010
Refrigerator/freezer won't stay cold.
Refrigerator won't stay cold. first the entire refrigerator/freezer thawed. i called out repair, they replaced the defrost timer. the r/f got so cold it froze everything solid. repairman came out again, replaced the thermostat. r/f got a little cold, then everything thawed again, ruined all the food. repairman came out 3rd time, re-replaced defrost timer. worked for 2 days, then everything thawed again. today (2 days after big thaw) i turned the coldness indicators all the way to the right (coldest), and it has been working, but all my stuff is still in coolers. the r/f was mfg 12/99, it shouldn't be broken yet. the repairman says maybe it's the compressor, but no way i'm repairing that. i've spent $400 already trying to fix this thing.
Kelly
Level 3:
  • Whirlpool Master 3,740 Answers
  • Posted on Jan 02, 2010
Kelly
Whirlpool Master
Level 3:
Answers
3740
Questions
Helped
2162210
Points
12091
With the defrost timer being replaced already it sounds as if the repairman is not looking at the real problem. Unit works for 2 days then things start thawing. Hint Hint... it is not defrosting. There is a heating element inside the freezer section attached underneath the internal tubing that melts the ice every 6 to 8 hours via the defrost timer depending on the defrost timer installed. To prove that it is not defrosting..... just unplug the unit and place a stand fan blowing into the freezer for about 90 minutes. I would bet that once you plug it back in it wil work for 2 days and the problem once again repeats. With 2 calls on the same unit and you still have the same problem I would be calling the service people back and demand they fully troubleshoot the defrosting element and thermostat. Personally this is an unstatisfactory performance of an in home service by a repairman. With the exception of a new part if required, they should wave any labor and service call fees.
Testimonial: "Thanks! The repairman also replaced the thermostat, though. What should I ask him to do this time? Replacements were: timer, thermo, timer."
  • Kelly
    Kelly Jan 04, 2010
    I know this sounds sarcastic but I would simply ask him to fix it. I mentioned the defroting heating element in my last post. It is time for some multi-meter use checking for continuity point to point in the defrost circuit. A good tech would have done this when the supposedly need came for a 2 nd defrost timer to be installed. The only things in the circuit that have not been checked the are wires for power and grounds along with the defrost heating element.
    Again as I said in my first reply: Personally this is an unstatisfactory performance of an in home service by a repairman. With the exception of any new part if required, they should wave any labor and service call fees.
Freezer is thawing
Below link will help you .
However i suggest get a repairman if initial checks dont solve your problem .
However ta
ke a note of the points just to be sure hes doing the right thing .
https://removeandreplace.com/2016/11/08/my-refrigerator-wont-stay-cold-food-in-freezer-thawing-what-could-be-the-problem/
1helpful
Freezer won't stay cold
What is the model number of your unit?
Hotpoint side by side refrigerator. Freezer stopped blowing cold air while refrigerator side continued to cool. Freezer was totally thawed when I discovered problem but refrigerator side was still...
Hi
Check the freezer to ensure it isn't over loaded with food stuff; reason being air must flow freely threw out the entire refrigerator in order for the thermostat to work correctly. Also check whether the unit needs defrosting or not. You should also check the coils on the rear of the refrigerator and make sure they are clean and dust free. If you still have problems after trying the above; you may need to call a repair service to come out and check the unit
Please check the bellow links to have a detailed idea related to your issue:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnotcool
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
http://www.applianceaid.com/frig_notcold.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
The freezer is thawing and the refrigerator is not staying very cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Freezer wont stay cold, it thawed out, average temperature in freezer has been 46 degrees
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
My Estate by Whirlpool freezer coils freeze up and both the freezer and lower compartments won't stay cold. I can manually thaw the freezer and it works ok for a few days then does it again
You have a problem with the automatic defrost cycle, it is typically the defrost control, which is located in the compartment next to the thermostat or cold control. If you send me your entire model number from the tag on the inside I can get you the part number needed.
Not getting cold anymore
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
2answers
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
