How do I get on my computer without a reset disk?
How to access
Windows Vista without reset disk?
Reference to:
Forgot
Windows 7 Password and No Reset Disk - How to Get in?
This passage is
mainly about how to reset Windows 7 forgotten password without reset disk, but
it is also applied to Windows Vista.
Another
administrator, Windows install CD, Ophcrack and Windows Password
Genius can be used to reset Windows 7 forgotten password.
Recommend you two most popular password recovery tools.The average person will use it first and many case proved that they can perfectly reset the windows vista password.
Ophcrack(500M)
Ophcrack is one of the most popular free Windows password cracker based on rainbow tables. It can help you reset Windows password less than 14 characters. Once you forgot Windows 7 password, it is a good choice to download the version compatible with Window 7. However, many Windows users failed to recover Windows password as its large ISO file which is more than
496MB.
Download:http://ophcrack.sourceforge.net/download.php
Windows Password Rescuer(34.3M)
Windows Password Rescuer is a highly appreciated Windows password recovery toolkit, especially designed for novice or new beginners. With this tool, you can get instant access to locked computer without the old password and computer skills. Prepare a bootable CD/DVD or USB flash drive and follow these 4 steps with less than 5 minutes.
Step 1: Download Windows Password Rescuer Professional and install it in any available computer
Step 2: Burn a bootable CD/DVD or USB flash drive
Step 3: BIOS settings of your locked computer to make it boot from CD/DVD or USB flash drive
Step 4: Reset Windows 7 password successfully
Download: http://www.daossoft.com/download.html
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
If you lost windows password, you can go into safe mode (F8 when booting up) to recover windows password, but you forgot administrator password, that way doesn't work. you must use software to recover administrator password. This method is very easy. You can go to this site http://www.reset-windows-password.com/how-to-reset-windows-password.html
Forgot Windows 7 Password, you can remove or reset it. For removing Windows Passwords in safety, I highly recommend windows password reset tools. Last week, and then I downloaded one and used it to remove the lost password successfully. http://www.reset-windows-password.com/reset-windows-7-password.html
Once you forgot admin password in windows vista, you can bypass windows vista password with third-party password reset tools, take Windows Login recovery for Example, it is professional software woking for windows vista password reset. You can download it and follow its guide to burn a password reset CD/DVD or USB falsh drive to get your password reset or bypassed.
For removing Windows login Passwords safely, I strongly recommend windows password program. Few days ago, I downloaded one at http://www.reset-windows-password.com I burned it to a Usb memory card. Booting up and clearing my password within just 5 minutes
I think the best way for you is trying hard to remember the password. If you really cannot remember, you can reset password from another user account with administrator credentials or Do-It-Yourself (DIY) third party recovery tool. Windows password seeker, maybe can help you.http://www.passwordseeker.com
Forgot windows vista password?Do not be so anxious. I know a tool which can help you bypass windows vista password, need not to reinstall the windows OS, its safely and easily.By using "Any Windows Password Recovery 3.0 " ,could be helpful.
I would like to introduce "Windows Login Recovery". It not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password. I Wrote it to an old 128mb USB flash drive to recover windows password. Booting up and clearing a password takes a minute or two works like a charm. You can download it from http://www.windowsloginrecovery.com
It is not so troublesome that you forgot Windows password, you can see this article about Windows 7/Vista/XP/2008/2003/2000 password recovery. Two steps:
1. Create a password reset disk;
2. Reset Windows 7/Vista/XP/2008/2003/2000 administator password offline!
