Since you used an Ipod battery instead of a Garmin compatible one, I would guess to say that it is not quite compatible. Even within the Ipod family, notwithstanding the physical limitations, the battery are not usually compatible because of variations some of which I would describe below:
- Battery has two wire and the regulator is on the device itself.
- Battery has two wires and has an inbuilt regulator (small circuit board fitted to the battery).
- Battery has three wires of which one is used by the device to control the charging
- Battery has three wires and inbuilt regulator (small circuit board fitted to the battery) of which one is used by the device as status indicator.
Hope it helps you do your own diagnostics but be very careful especially if the rechargeable Lithium battery is bulging as they do explode when not charged correctly! NEVER PIERCE A BULGING LI BATTERY!
