To hook up a computer desktop PC you will only need the basic four items with the appropriate cables PC + power cable Monitor +monitor cable + power cable Mouse Keyboard Insert cables into the appropriate slots according to shape and your done
Tries Element website itself if ur LCD tv model still in the market u can download manual for free not look for their phone number like 1-800..call them pay them a fee they'll send out a copy of the manual to u.U have a LCD monitor now hook up to ur computer right now to used as a monitor now wright?Yes.Take that VGA cable out from ur computer and ur old LCD monitor VGA cable out of the VGA ports just take ur hand and unscrew the VGA cable.Used ur old LCD monitor VGA cable and hook up to the LCD tv VGA port and to ur computer VGA computer graphic card port or computer monitor port hook up the other end.Turn on ur Computer and tv on used the sides button of the tv find one that said INPUT push it a few times should find ur tv mode 1,2.3 ur computer is on as a monitor.
Hi, Yellow and white pins cable is called AV Cable, it is to hook camera with TV. It wont hook camera with computer. You need USB cable to connect camera with computer. Required USB cable is available in Sony Accessories Store under following part number.. 319698101 ....
CODE (USB 5P) CONNECTION Thanks.
Use the VGA cable,that was hook up by ur previous LCD monitor.Or tries websites like Amazon.com,Ebay.com to buy a HDMI cable.U can hook the computer by the HDMI cable too.
From Singerco.com FAQs:
Q.
My computer only has USB ports. Can you recommend a Serial (nine pin) to USB converter cable that will work with the Professional Sew Ware™ 2.00a?
A.
We have found that the PSW works best on newer computers when the USB serial adapter cable has not only compatible drivers for the Windows operating system but also a FTDI chip. We have found this FTDI chip in the cable which is listed below: CUSB-232A available from Computerplug.com and Cablesalesusa.com. Any USB to serial adapter with an FTDI chip will work. These cables will work for Windows XP, VISTA, and 7.
all of your computers should get hooked up in ports 1-4 and the WAN port should be hooked up to your broad band router from your internet service provider. so if your first computer is hooked up to port 1 just plug your second into port 2 and every thing will work fine.
you can hook it by usb cable or network cable, usb cable just plug to machine and to computer and load the driver, network u have to hook cable from machine to router or switch, and u have to put ip address of the machine and load the driver
If I understand the question right are you trying to hear sound from your computer through your bose system? If you are then you need to hook a 1/8 mm headphone jack style cable on one end to the headphone jack on computer and on the other end of the cable you need a standard red and white rca type connection that hooks to back of bose system for sound. This cable is called a mini to rca stereo cable the pin connection for the computer has 2 little black bands around the plug there are 2 bands for 2 channel stereo sound.
You need a router or a wireless router to do that. If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
