Palm Tungsten T3 is frozen, tried synching, ng HELP
Take the battery off for 15 seconds and put it back again. you need to reboot your Palm at least once a week. goodluck!!!
Your handheld does not turn on when you press the power button, or
your handheld does not respond when you tap it
1. Press any application button to see if you can turn on your handheld that way.
2. Perform a soft reset:
a. Slide open your handheld.
b. Use the tip of your stylus or an unfolded paper clip (or
similar object without a sharp tip) to gently press the
reset button inside the hole on the back panel of your
handheld.
3. Charge your handheld for another full two hours.
a. Place your handheld in the cradle.
b. Make sure the indicator light is on.
or
Symptoms caused by third-party applications
Some third-party applications may not have been upgraded to be compatible with your new Palm™
handheld. If a third-party application is NOT compatible, the following symptoms may occur on
your handheld after you perform a HotSync operation:
• Device freeze
• Device freeze or reset when an application is opened
• Slow performance
• Unusual screen display
• Difficulties using handheld features
• Uneven sound quality
• Device reset
It doesnt work
how does one take the battery out?
Title
