The most simple home way to fix this type of problem without opening is using compressed air.
Most main computer/electronic shops sell cans of compressed air. shoot a can down your cooling air exhaust grills and it should remove all dust and have you happy for a few months.
A word of warning, do not do white while laptop is powered on, or just after you turn it off! this is because compressed air is VERY cold, and if your laptop is still hot, the rapid change in temperature will crack your motherboard, and cost you a pretty penny to replace. so give your laptop 30minutes to cool down before using a can of compressed air.
Also compressed air is VERY cheap to purchase and F.Y.I. most repair shops use it to fix overheating issues in computers and laptops. even game systems.
Hope this helps
Testimonial: "I tired this and it worked for about an hour, now the fan is sounding up again"
Spray some compressed air through the slots.
Testimonial: "worked for a short time, maybe I need to open it up and spray the air"
USE A VACUUM - DONT MOVE THE DUST INTO AREAS THAT MAKES IT WORSE.
Testimonial: "Appreciate the suggestion, makes sense and I'll try this next."
