I've disconnected the wires from my Gigabyte GA-7ZX rev 1.01 motherboard, and now need instruction on re-connecting them, especially the square plug on wires coming from the power supply and the front cover wires. Front cover wire terminals are all labeled, but I can't find similarly labeled connection points on the motherboard.
SOURCE: need a diagram of motherboard pins
The link below will take you directly to the GA-7ZX family page. You will have to figure out which revision/series board you have and download the appropriate manual. http://www.gigabyte.com.tw/Support/Motherboard/Manual_List.aspx?Keyword=GA-7ZX. Good luck and don't forget to rate this post.
SOURCE: motherboard ga-7zx
You posted this problem twice. I have replied to each differently.
The motherboard manuals would be supplied by the manufacturer, in this case a company named Gigabyte, which is not a part of nor related in any way to FixYa.com website. The following is a link to the support page for this motherboard on the Gigabyte website:)
http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=1369
There are three revisions of this motherboard {1.x, 5.0 and 5.1} and NONE of them have onboard VGA. All use an add-in 4X AGP VGA card that goes into the brown slot at the top of the white PCI slots.
Compare your motherboard to the pictures available at Gigabytes' support page (the link above) to make sure we are talking about the same motherboard, although as far as I can see there was no other manufacturer that made a motherboard with the GA-7ZX designation. Please verify and repost your results.
SOURCE: i have a Gigabyte-GA-8SIMLNF motherboard and
The memory that should work is advertised as PC2100 DDR266. make sure it is the correct speed. I have found sites that list this memory with your exact board.
Check here http://www.memoryx.net/ga8simlnf.html
also it may need non ecc as listed in the adds
SOURCE: Gigabyte GA-8I865GME-775-RH Motherboard core 2
You can download the device drivers from Gigabyte WEBsupport site, select your model motherboard to download :-http://www.gigabyte.com/support-downloads/support-downloads.aspx
