Here is what I found on the Web. You can click on the link below, to see Full Instructions. If you find this helpful, pls rate me.
http://h10032.www1.hp.com/ctg/Manual/c00687555.pdf
View estimated ink levels
Follow these instructions to view the estimated ink levels of the print cartridges that are installed in the printer:
1. Open the printer Toolbox.
2. Click the Estimated Ink Level tab.
Note If the print cartridges were used before being installed in the printer, the
estimated ink levels will not appear on the Estimated Ink Level tab.
The Estimated Ink Level tab also contains print cartridge ordering information. To view
this information, click the Print Cartridge Information button.
Thanks and good luck.......
Pls rate me
SOURCE: what type of ink does my hp deskjet d4160 printer take?
HP 98 for Black and HP 93 for Color.
SOURCE: need software for hp desktop printer D4160
Go to HP site, support, drivers and software and it will ask for model info and you can download them
SOURCE: can i use a #94
No, you cannot, only 93: Tri-color, 98: Black and 99: Photo are compatible with this Model. Hope this helps. Good Luck.
Thanks for using FixYa.
