I have a kenmore elite model 16582200 built in and wont drain and key pad wont lite up i do not have an owners manual can you help
Item #959376(fuse) will need to be replaced.
Unplug the dishwasher.
Remove the 6 screws holding the control panel on.
The fuse is on the top right side of the control panel. It has 2 wires going to it,usually black and white.
Remove the wires and check the fuse with a meter set for continuity. No continuity is a bad fuse.
If the fuse checks OK use the meter on the micro door switch found under the door latch.
Remove the wires to the switch,touch the meter leads to the 2 terminals and manually push the switch button in. If no reading on the meter the door switch is bad..
