27 ton troy built log splitter, used once. started engine ran for about 10 sec. engine shut down on its own and now it seems as if the engine is locked up. 160cc honda motor. oil is full, hydraulics is full. gas is full.
Ensure that the motor oil in it was not presivation oil. some machines have a thick oil put in it to stop the engine rusting if stored for a long time this needs to be replaced before starting the engine. if the engine oil is dark and very thick this may be the case and the engine will need to be stripped to dislodge the piston. but that usually happens in a longer time than 10 seconds.
if not then suspect the motor has had some major mechanical failure such as a crank shaft break. remove the injectors or plugs to see if the motor will crank round without compression.
