Whenever I have my phone connected to the charger, t says invalid battery, and if I take it off the charger it won't work.
Any help??
It will only work when connected to the charger.Whenever I have my phone connected to the charger, t says invalid battery, and if I take it off the charger it won't work.
Any help??
My phone says invalid battery and won't work unless plugged in to charger.My phone says invalid battery and won't work unless plugged in to charger.
AnonymousMar 24, 2008
Even I Have The Same Problem .......:[ Im So Sad.......I love My Phone SOo much..........i Just Charged da 4n Once Fully and i Offed It.....Now it Wont Even *** on It Once Cam On n Said InVALEven I Have The Same Problem .......:[ Im So Sad.......I love My Phone SOo much..........i Just Charged da 4n Once Fully and i Offed It.....Now it Wont Even *** on It Once Cam On n Said InVAL
I am also getting the invalid battery message as well as unable to charge message. Now I am just getting a white screen and then it just turns off. It has full charge, so that is not the issue..any suggestions?? ThanksI am also getting the invalid battery message as well as unable to charge message. Now I am just getting a white screen and then it just turns off. It has full charge, so that is not the issue..any suggestions?? Thanks
AnonymousJun 26, 2008
my phone says invalid battery and it doesn't get charged. I tried to take off the battery and re insert it, but nothing seems to work
I am not familiar with the TracFone V170 but most phones now communicate with the battery. They do this because the battery contains a small computer chip which monitors the charge state, temperature etc.. If this chip is faulty or missing because it is a cheap copy battery, some phones will not work properly. They usually power up okay but will not charge or will charge really slowly. There are various messages they may give including "alien battery", "Invalid Battery" to name a few. If it is unable to communicate with the battery, it will not usually charge as fast as it could because it cannot tell if the battery is overheating so it will always trickle charge an unknown battery.
You will notice a battery like this because it has at least three battery connections. Older ones only had two.
try use a good battery. if it does not work, try check on the connecting pins on the battery connector of your cellphone. if still a problem, try disassemble the cellphone to check the battery interface on your cellphone, clean both connector and the interface of your cellphone... if still a problem, best to repair it to a nearest cellphone technician...
If you drained the battery try to recharge again from your pc or laptop, I am sure that there is nothing wrong happened when you left your mobile phone connected with your pc. You PC is off, so there is no power supply that will flow to your mobile or charger. It make sense that it just drained. Try to buy a new battery and test it, let's see if your mobile will work again, if you don't want to buy a new battery to waste some penny. Just bring your phone to your nearest technical shop to test it. I guess they will not charge you for that.
Any help??
PLEASE HELP SOME ONE!!
[email protected]
EMAIL!!!
I have this same problem. Can anyone help?
Thank you.
