Dear Friend I will rather suggest you for the LAN instead of data transfer cable. By using LAN you can share Data, Documents, pictures, printers, faxes,
and storage devices at High Speed.
The easiest way is with a USB data transfer cable. You just plug it into both computers, run the software and select the data to move. The sit back and in just a few minutes the data is moved. You should be able to get the cable from a local computer store, if not contact us at the address below. We have them available for shipment to you, they run $18.00 plus shipping.
I hope this helps, if so please rate our solution.
There are three sets of items that you need to transfer.
It would be best to use an external USB drive and keep the data on the drive as a backup.
1. Settings (Internet favorites, desktop settings, cookies, address book, etc.)
2. Data (My Documents, and multimedia content)
3. Programs
It would be easy if the old computer was also a Dell; however, you can't simply "copy" to the new computer.
#1. Settings: There is a built-in utility called "Files and Settings Transfer Wizard". [Start] [All Programs] [Accessories] [System Tools] [Files and Settings Transfer Wizard]
#2. The transfer wizard has an option to copy "settings only", "Data Only", Settings and Data". Transfer only the settings and then transfer the data. It will go much smoother.
#3. Some programs are already on your new computer; however, unless the old computer was also a Dell, you will have to re-install most or all of your programs like MS Office, Printers, Scanners, Camera and Video applications, etc.
If you need more detail, please post a comment... Thanks .
Hi Im not sure you can transfer over a USB cable with different OS and filesystems. easiast way is to buy a usb harddrive or usbstick copy data to that. or if the old computer have a networkcard to transfer over a crossover cable or true a network Hub/switch..
USB (Universal Serial Bus) flash drives are high-speed, high-capacity memory devices designed for long-term data storage and easy transport among PCs. The host PC treats the device just like a drive, so you can transfer files of all types to and from the device. Because the device emulates a drive, it supports any type of file, including audio files (such as MP3s) and graphics files (such as JPEGs [Joint Photographic Experts Group] and BMPs [bit map]). In addition, USB flash drives can easily support applications, CAD (computer-aided design) drawings, and a wealth of personal information you'd rather not leave on any particular PC. Even so, most USB flash drives are smaller than a pack of gum and can easily fit onto a key ring.
Years ago, users often referred to the practice of using floppies to transport files among PCs as sneakernet. Because USB flash drive manufacturers designed these devices for transport among PCs, their increasing popularity has given rise to a "new sneakernet."
