Question about ESQ 07301132 Aerodyne watch
I have an ESQ Aerodyne and the time set by the
I have an ESQ Aerodyne and the time set on the watch and the time shown by the hands is different. Basically, I can set it for the correct time, but the watch will display another time. I have double checked to make sure that I am setting the watch to the correct time, year, month and day. Any ideas on how to correct this? Is this just a sign that I need a new battery?
    Problem Solver:
  • 9 Answers
This watch needs to be taken in as this is not proper time telling. has the johnson rod been used yet. if not, do so. if so have it taken in and checked with a caver device.
Posted on Jan 01, 2010
SOURCE:
How do I set the time and how do I get a user manual.
1. set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date
2. if off sync between analog and digital clock happen. You need to resyn
step 1: follow the instruction 1 to set digital clock to 12:00.
step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync mode.
step 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.
step 4: push the pusher at 3:00 to exit the sync mode.
step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Jun 18, 2011 | ESQ 07301132 Aerodyne watch
I just bought this watch but can't figure out how to set: time, date, and alarm. Please help. Thank you
2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Jan 14, 2011 | ESQ 07301132 Aerodyne watch
How do you change the country
Thank you for contacting FixYa.
I would contact ESQ at the following link:
http://www.esqswiss.com/
Best regards. Jewel
Sep 13, 2010 | ESQ 07301132 Aerodyne watch
Setting time day date in ESQ Aerodyne
Jul 26, 2010 | ESQ 07301132 Aerodyne watch
New battery install in my esq e-5290 watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ESQ watch manuals. Rate me, please.
Mar 05, 2010 | Watches
Watch doesn't work
It would be difficult to state with certainty, because it wouldn't likely be possible to determine how long the watch was in storage before you received it. Most watches will need batteries between 2-5 years after their manufacture.
Higher-priced watches could easily be that long on the shelf before sale, but I would contact the seller with your complaint. The seller should at least be conscientious enough to ensure the watch is running prior to shipment.
Nov 19, 2009 | ESQ 07301132 Aerodyne watch
My second hand on my esq bracer chronograph resets to a few seconds before zero...how do i fix it?
Mine did the same. I fixed it. Go here
http://www.esqbymovado.com/pdf/ESQ_Fusion_Instructions.pdf
Jun 06, 2009 | ESQ Swiss Bracer 07301091 Watch for Men
Divers watch needs refurbished & repair.
http://service.movadogroup.com/pages.cfm?pid=4CD4575A-AB5B-AB72-9CDA4CE49DDD9176
This is a link to the Movado Group service centers, they make ESQ watches. It appears your watch has had water seep inside the case. It could be the seals around the caseback or crown. Whether repair is worth it, is up to you. I have had Casio dive watches I have sent into repair because I liked them, not for the value of the watch. In general ESQ makes a nice watch and if you like it, why not see what repair would cost. However, if this is a moisture problem, more than just visible corrosion has probably occured and the movement could compromised, if that is the case the costs of repair might outweigh just purchasing another watch. Good luck and I hope you found this helpful,
Apr 03, 2009 | ESQ Blackfin 300m Dive Watch Black Dial...
How do you set time for the ESQ aerodyne watch 07301132 ?
i need to remove links from my sons fossil watch how do you do this?
Dec 25, 2008 | ESQ 07301132 Aerodyne watch
ESQ watch parts
Type in your browser: 1) ESQ watch bands
2) EQS watches
3) ESQ watch bracelets
4) ESQ watch parts
Try all of these and you will find numerous sites (too many to list here).
Dec 21, 2008 | Watches
ESQ 07301132  Aerodyne watch Logo
765 people viewed this question
Top ESQ Watches Experts
Arturs Kalnins
Arturs Kalnins
Steve Allison
Steve Allison
Are you an ESQ Watch Expert? Answer questions, earn points and help others
