Remove the battery, plug the laptop up into the wall outlet and turn it on. If it boots fine then its your battery. Other then that the possibilities are this.
1. Your Processor has gone to junk
2. your hard drive has fried
3. or the pc board has fried.
Do you hear the hard drive spinning at all? if not this would be the first thing i would check. Only problem only real way to test it at home is if you got an other laptop put it in their and turn it on or buy a new one.
To test the board best way to do is open up your laptop by removing screws on the bottom, and looking over the bored and seeing if you see any burnt areas.
To test the CPU, really isnt a easy way to test this either, other then put a new one in.
IMPORTANT: if your laptop is under warenty opening up your laptop and trying to replace these will avoid your warrenty with this company.
best thing to do if under warrenty is to contact sony vaio,
if not take it to a repair shop, or try replacing the above things, starting with the hardrive
also make sure the ram is pushed into the board. (it looks like a rectangle)
