Archos 504 500870 Digital Media Player Logo
Posted on Jan 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the reset button on my archos 504? - Archos 504 500870 Digital Media Player
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Jan 01, 2010
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3072811
Points
27242
Take the battery off. Just beside the 4 battery terminal connectors there is a little button about 5 mm (1/4 "). Push it with the tip of a pen for 10 seconds and voila!! Hope this helps.
3helpful
Archos 504 comes on when plugged in briefly but no charge
I had the exact same problem, I looked a bit on the net and I found the answer. What you have to do is push the reset button when your archos isn't plugged on. The reset button is located behind the battery ( you'll have to the remove the battery ) near the pins that connects the archos to its battery. It looks like a gold circle and if you push it you'll see it's a button. After pushing the reset button try to put the battery on back again and replug your archos, it should work normally now.
Good luck !
5helpful
No power whatsoever to my Archos 504
There is little documentation regarding the reset. However there is one in the Archos 504. If you take the battery off and look at the connecting Pins of the battery of the main unit. You will see a small Gold Button (looks like the circuit). This is the main reset button. If you Press it all will be good. You will not loose anything unless you have a Main File corrept but at least you will get function back so you can fix the firm ware.
I hope this helps you.
Ed
17helpful
My Archos 504 will not power up.
Press the Reset button on the inside of the unit with the battery removed. This should solve the Problem. If not you may need to send it in.
Reset button is located under the battery. So remove the battery and loo for the button at the end of the archos where the battery pins make contact. To the right of those and half way down between the pins and the case of the hard drive will be a gold round looking circuit. this is the reset. Press it and off you go.
Thanks,
Ed
1helpful
2answers
Archos recovery 504
Try to press and hold the reset button (a little 4mm diameter golden button behind the battery right on the microchip) and then turn it on again
4helpful
3answers
Archos 504 RESET button
Please open Battery cover and PRess Small Golden button just near the HDD , it will restart the Devie
5helpful
2answers
Archos screen only
solution found!!!!!!!!!!!!!!!!!!!!!!!!!!! thank you so much for the support of the Archos team. here is what i did to repair my 504
if your "reset" button doesn't help at all, this is what you'll do.
If you power on the unit by pressing and holding the TV/LCD button and power
button simultaneously the unit will boot into a recovery screen. Once in this
screen choose "Repair Disk" and follow the on screen instructions.
When prompted, please place the following file into the 'root directory' of
the unit:
http://update.archos.com/4/a504/a504_r1.6.53/a504.aos
before i found this solution, i've already given up on my 504, but now it's back!!!! REBIRTH!!!
thanks once again to Tony H from Archos Technical Support
My archos 504 has recovery code4 and asking for update file
its **** **** around with it press the reset button several times
i have it it sucks
Archos 504
try resetting it via the button under the battery cover next to the hard drive, and if not, connect it to your pc, and format it as quick as poss.
29helpful
10answers
Bless you guys...!
I thook the chance n press the reset button....Nuthing has been erased from my hard drive!!! :D :D :D
1helpful
2answers
Archos 504
I had a similar problem remove the battery and push the gold coloured reset button. It worked on mine, You don't lose any info doing this. I got the advice from the Archos support phone number CC
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
