Run it through the rinse cycle again, then when that's done...
There is a strainer on the drain pump that is clogged. The manual does not mention this at all, it merely states the drain hose is kinked or clogged.
Under the front door there is a panel that is the width of the machine and is held in place by two screws, one on either side.
When you remove that you will see the pump and the the strainer attached to it. Unscrew the strainer (put a small pan under it to catch excess water) and remove to remove the junk accumulated.
Also, attached to the panel is another manual that refers to the error codes you are seeing.
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about ¼" or until a click is heard.
6. The door may now be opened.
