4 Door. Drivers side rear window has dropped down 4 or 5 inches. Window can be raised by hand but falls down again. Want to fix myself. How do I remove door panel to get to the window mechanism? What is likely the problem with the window mechanism? Can I buy parts on line to fix?
Window regulator has failed. Look for an after market one the GM replacement is junk. Usually it is a clip that holds the cable to run window up and down. probably a safety clip used if someone gets cought in the window, GM will charge you over $400 for the fix. not hard I have it down to about 30 min. and around $100 for the regulator.
