The Main second/date hand is going counterclockwise.This is a recently purchased watch so it is not fully charged. But I did not find in the instructions explaining a counterclockwise motion. Thanks.
As it is new and by definition hands should not run backward, I suggest you take it back and ask for a replacement! As it is new and by definition hands should not run backward, I suggest you take it back and ask for a replacement!
You can't post conmments that contain an email address.
read the instruction manual,
Geneva Watches with Two or Three Hands
Pull the crown out until you feel a click.
Turn the crown counterclockwise until you have the correct time.
Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
Pull the crown out until you feel two clicks. This second click position allows you to set the time.
Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
Pull the crown out until you feel one click. This first click position allows you to set the date.
Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
Pull the crown out until you feel two clicks. This second click position allows you to set the day.
Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
Pull the crown out until you feel a second click to set the time or the 24-hour hand.
Turn the crown clockwise until you have the correct time, then push the crown in to set it.
Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
Pull the crown out two clicks. This second click position allows you to set the time.
Stop and start the chronograph by pressing the PA button, located above the crown.
Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
Wind the mainspring by turning the crown 15 to 20 times clockwise.
Pull the crown out until it clicks.
Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Changing the date for the FT500WVB watch is easy. Just pull out the stem of the watch to its first stop. Then turn the stem counter clockwise a couple of twists and the displayed date will increment (that is increase) by one day and you will hear a little click. Keep twisting the stem counterclockwise and the date will increase by one each time with a little click. Stop when you reach the correct date and push the stem back in to its fully seated rest position. Note- be careful not to change the date when the watch displays a time between 9pm and 1 am as setting the date in this time range may cause the watch to increment the date at noon rather than midnight.
Note also that if you want to set the time you just pull out the stem to its second stop position and twist the stem to advance the position of the hands of the watch. Then when the time is set, push the stem back in to its lowest rest position. So remember- first stem stop sets the date and second stem stop sets the time. That's it.
Seiko watches from this period should have a setting stem that pull out half-way and fully. Pulling the stem out fully permits you to set the time. Pulling the stem out half-way should let you set the date by moving the crown forward/clockwise and set the day of the week by moving the crown backward/counterclockwise.
However, for this to work correctly, the watch must have the correct set stem. I have worked with a number of watches, including Seikos, where a generic stem was substituted after someone accidentally pulled out the crown and stem (Seiko replacement parts can be tough to find in the U.S., especially for discontinued models). If an incorrect stem has been installed, the day/date setting procedure I've just described may no longer work correctly. At that point, setting the date involves advancing the hands to get to the right date; day of the week may not be able to be set at all.
Pull the crown of the analog/date Cartier watch and rotate it clockwise or counterclockwise until you see the date advance in the display window at about 1 a.m.
Use the quick date set method by rotating the crown counterclockwise after reaching 1 a.m. until the hands reach 7:30 p.m. Then again rotate the crown clockwise back to 1 a.m. Repeat the procedure until the correct date is displayed.
Adjust the date forward or backward 12 hours if your Cartier watch changes the date at the noon hour.
Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
Good luck.
Sector Chronograph Watch Instructions
Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
Sector Dual-Time Watch Instructions
Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
Sector Ana-Digi Watch Instructions
Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
Since you didnt tell me what KIND of watch it is I am giving you a general instructions.
Wait until the second hand is at zero (the top of the dial). Then pull the crown knob out as far as it will go to set the time on your watch. Turn the knob in either direction and look at the three additional hands on the time dials of your watch: the minute hand, the hour hand and the 24-hour hand.
Step 2
Stop turning the knob when all minute and hour hands are pointing to the correct time. Pay special attention to the 24-hour hand so that you have a.m. or p.m. correct.
Step 3
Push the knob back in exactly when a new minute is starting so that your second hand will be correct. Use another clock you know to be accurate as a reference, such as the government clock available online.
Step 4
Pull the knob out halfway so you can set the date. Turn it counterclockwise until you notice the date on the watch changing. Stop it and push the knob back in to its starting position once you reach the correct one. Try to set the date before 9 p.m. If you set it after that time, it may not register with your watch that it should switch the date at midnight. If this happens with your watch, just fix it the next day.
Step 5
Set the chronograph, or big dial, on your watch. It works like a stopwatch to let you time activities for up to one hour. Push the top button on the side of your watch to start it. Push it again to stop it. Push the bottom button on the side of your watch to reset it.
It would certainly help if next time you let us know what kind of watch it is you have, Best of luck.
I need to know if this watch is an automatic or quartz (battery-operated) watch. For either watch, your crown screws in clockwise- which, by the way, is on the right hand side of your watch, and looks like a miniature doorknob. Unscrew it COUNTERCLOCKWISE, then, if your watch has a date on the dial (face of watch), your crown will pull out in two different positions. The first position is for your day/date. Forward will either do the day or date and backwards will do the other. DO NOT SET YOUR WATCH BETWEEN 10 O'CLOCK AND 2 O'CLOCK, because it can ruin your watch. The second position (pull out completely) is for setting the time. Go around until the day and date changes so you're sure that you're on a.m. or p.m. and then set accordingly. Push the stem all the way back in - this is your winding mode if you have an automatic. Wind 50 times before use, or else it won't run correctly. Now, push the stem back in (it's spring-loaded), and turn it counterclockwise to seat the tap, then clockwise until it's completely screwed in.
