Question about Fossil Watch - Analog Silver Dial
I just received one of these watches (or I believe thism is the right one-it IS fossil) How do I adjust thd date? I've looked for the watch online and this was they call this watch "Fossil Analog Silver Dial" There is a little square on it for the date, but I don't know how to set it................. Please help!
    President:
  • 2,501 Answers
Go back to the web site and at the bottom of the page in faint lettering there are a number of options; one of them is customer care and they have the downloadable instructions for their watches.
Choose yours and download.
Posted on Jan 02, 2010
SOURCE:
Have a fossil fs4359 and can't set the date dial. How do I adjust it?
Mine is slightly different, but I suspect the date adjustment is the same. Pull the middle knob on the right out VERY gently. You have to stop at the first click. Then turn it to set the date.
Sep 06, 2016 | Fossil Watches
Out of date
try to pull the circle at the right side of your watch and then adjust it so that the date would move until the date is complied with the latest date today...
Jul 04, 2011 | Fossil Watch Style # FS4386
I cant adjust the date for my Fossil AM4205..help!
mcdevito75 here, If your Fossil watch has a winding stem it may have 2 positions, gently place a fingernail under the crown and lift as gently as possilble, this should allow you to adjust the date without having to cycle thru the 24 hours to get to the date you want. It may take practise but that first position should be there, Set the date to 1 day before the date you need, then set the watch normally the full 24 hour cycle to get the date you want, this way the watch date will set as suppose to at about mid-night for the next days date.
Aug 28, 2010 | Watches
Fossil bq 9011349908 cannot set date and day
mcdevito75 here, There are many versions of Foosil watch, If yours has a stem (winder) it"s 2 position, to set Day pull stem out and rotate the hands till the day appears, push stem in all the way, Now slip your fingernail just under the crown and lift stem to it"s first position this will allow the date to change. You can also visit Fossil Watch online at Fossil Watches.com or visit a small watch repair shop in your area for adjustment help.
Jun 27, 2010 | Bulova Watch
Changing the date on a fossil watch- how do you do it?
Which Fossil do you own?
Analog Date Watch:
Date Setting
  1. Pull the crown out to position 2.
  2. Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic:
Time and Date Setting
  1. Pull crown out to position 2 and rotate clockwise to set time.
  2. Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
  3. Push crown back to position 1.
Analog Digital:
Time and Calendar Setting
  1. Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
  2. Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
  3. Press pusher B to adjust digit.
  4. Press and hold pusher B to adjust digit automatically.
  5. If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions.
Hope this helps.
Dec 12, 2009 | Fossil Watches
NEED TO RESET THE TIME, NOT SURE HOW TO DO THIS
Go to www.fossil.com and go to customer care. Once there go to watch manuals and look for your watch.
Apr 06, 2009 | Fossil AU4003 Wristwatch
SETTING (DIGITAL) DAY/DATE ON THE FOSSIL JR9387
Follow this link and download proper instructions:
http://www.fossil.com/webapp/wcs/stores/servlet/StaticView?langId=-1&storeId=12052&catalogId=10052&page=Instructions&nav=custCareNav
Rate me, please.
Mar 24, 2009 | Fossil JR9388 Watch
Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Aug 08, 2008 | Fossil Philippe Starck PH1035 Wrist Watch
Philippe starck with fossil ph-2006
Fossil Contact Information Main support number 1-800-842-8621
Email support webguy@fossil.com
hope this helps
Mar 25, 2008 | Fossil Philippe Starck PH1026 Wrist Watch
Fossil Watch - Analog Silver Dial Logo
87 people viewed this question
Top Fossil Watches Experts
Arturs Kalnins
Arturs Kalnins
Ray Murphy
Are you a Fossil Watch Expert? Answer questions, earn points and help others
