Here is the belt you need to replace and the manual which has instructions:
Eureka Altima Belts
Owner's Guide
SOURCE: looking for Eureka belt 70646A for a Eureka The Boss upright
It should be a standard Eureka U belt. That number you have is not a good number. Most repair shops should have this one. The R belt is a real thin and different material.
SOURCE: how to change belt on eureka vacuum 2996
The information you're looking for can be found on page 8 of the manual via this link: http://www.eureka.com/service/manuals/80244.pdf
SOURCE: the belt broke on my vacuum
Remove the base plate. It is held with screws accessible from under the unit.
Inside you will see the beater bar and the belt.
Remove the beater bar. This is self explanatory once you see inside the power head.
Remove the old belt.
Find a replacement from your local dealer or online.
Replacement is the reverse of removal.
This is a simple job you only need a screwdriver.
Good luck, please rate this answer. Thanks.
SOURCE: broken belt
Eureka says size U BELT... NO!! I have tried this numerous times. I finally took off a belt from an old vac. and it works !!! dirt devil size 5 belt is the way to go!!
