CHECK your bios setting first, and make sure, in hard disk boot priority section, your external hard disk is recognised and set as the first boot device. YOU NEED TO BE SURE YOUR BIOS SUPPORT BOOTING FROM USB FIRST.
IF the hard disk is there u can do several stuff to boot it:(unplug any internal hard disk first, TO MAKE BYPASS CONFLECT ISSUES)
- make sure the drive is seen, whene you are trying to install windows.
- go to recovery console in the setup disk, and reset you master boot record, type:1- fixmbr (or fixmbr c:) >>> WHERE "C:" IS YOU WINDOWS INSTALLATION DESTINATION!
2- fixboot
and then restart and try again......
- try to download plopboot manager, burn it to disk, and boot it, try to load your hard disk frome there.
- install any boot loader, like lilo or grub if you are familiar with, they can boot any os you like!
You can always install Grub to your Master Boot Record of the initial internel hard disk, **** you need to have basic knowlege on how to edit the menu.lst inside grub folder, and basic knowlege of linux partitioning schemr, becoz GRUB need to be installed there as well, **** whene you are already familiar with its use, you can boot any thing you like, even with a friendly boot menu at startup alowing you to choose the option you want to boot.
N.B: make sure you have googled and read about grub, and how to install in, if u have a windows installation on the internal hard disk and afraid to loos it, there is a tool called super grub disk, google for it and download it, it can be installed from windows, and it can automaticaly load windows ntldr/boot.ini.
dg luck.
