Open the hood, there is a locking ring on the back side of the headlamp pod. Turn the locking ring counterclockwise to release it. slide the ring up the attaching wire. unplug the connector to the headlamp by releasing the lever latch. pull out the headlamp
when installing, line up the notches and reverse above proceedure
SOURCE: 1990 Ford F-150 flooding very badly
ok change the coolant temp sensor it will make it rich if it is bad good luck.
SOURCE: checking transmiission fluid on 1990 ford f-150
look about half way up the drivers side of the transmission there will be a large 'bolt' head its a fill plug loosen it, its only about a half inch long take it out and if fluid runs out or you can take a finger and touch fluid inside the transmission you are good
SOURCE: can 1985 f-150 tailgate fit on a 1990 f-150
Probably will. The models really changed significantly in 1993. Models for 1984 to 1992 were pretty much the same. Suggest you measure everything on both to make sure. They are not hard to remover/replace.
SOURCE: blower doesnt work on 1990 ford van e-150. I
most likely the blower motor! but could be the blower motor resistor! does it work on high setting? if so it is the blower resistor if not most likely the blower itself!
