When you install the amplifier the power light is on, we plugged up the remote wire and the speaker wires to the terminals. The sub is getting no power at all. The amp is a Rockford Fosgate T10001 bd. Thank you.
For a test
disconnect everything from the remote terminal in the amplifier
get a bit of wire and connect the remote terminal to a 12 volt supply
does it turn on now?
if yes then check the remote wire from the radio does it become 12v when the radio is on and 0v when it is off
if no make sure that the amplifier has been grounded properly and all the power cables are connected properly
how to run two Rockford fosgate t10001 bd
