Pioneer x910bt. When I plug in my iphone, the screen is showing that the ipod is playing but there is not sound. have tried both av1 and av2 - no luck, help?
If you are using the av ipod cable that plugs into the usb and the red,white,yellow rcas, you will have change a setting in the audio section for the audio to work, if you go into the AV settings, the first option with say AV1 input, press it until it changes to IPOD. you should then have audio, if that doesn't work, the the rcas are improperly connected to the radio. hope this helps
