I was turning on the oven when I must have hit some keys by mistake and now the door is locked and F9 is flashing. The oven is cold so I don't understand why I can't clear the door lock.
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Hello meathead4094 - Often when the LOCK light is flashing, it is because there is door malfunction. Try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Typically, this will clear the flashing. If issue persists, the range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I would strongly recommend contacting a professional to get the appropriate diagnosis prior to make any unnecessary part replacements.
