You will probably se the light flashes 7 times then pause and then repeats.this indicates that your unit did not heat the water correctly.
most likely youi dont have enough hot water going into the unit, 120degrees or more, or the latch is not engaging fully. check the temps and then the latch strike. its on the tank and is chrome type metal bracket.
it should be bent down towards the door frame until it just clears the door. if its too high it wont make the door switches work properly and then no heating of the water.
try it.
to get rid of the flashing, push the high temp wash, air dry, high temp wash, air dry. then it will go thru a test cycle and back to normal.
takes about 7-10 minutes.
tom
