The nikon d80 you pointed out is a solid good camera. Id suggest buying it, if you are sure your lenses fit, didnt bother to check But I know Nikon is the way to go!
all canon serial #'s are located on the back of the copier on a label. there might be a listing of the serial # in the menu options if you can get it to print out a configuration page.
Open the LCD, and you should see a "Batt Release" lever on the body. Slide this lever to the front and remove the battery from the rear of the camera (it slides down). The serial number is a ten or twelve digit number on a plate beneath the battery.
E354 •When turning ON the power, inconsistency of the serial No. of the serial number PCB and that of the controller PCB (SRAM)/counter memory is detected. •When turning ON the power, it is detected that no serial numbers are assigned to the serial number PCB and the controller PCB (SRAM)/ counter memory , if you are try to change the counter pcb to get rid of high meter reading this error is possible, this a security measure of canon to prevent meter tampering
That's good info. The trouble is that Quantaray makes lenses for different bodies. Your lens could be made for Minolta, Nikon, Canon or other. You may be able to find a universal adapter but first you need to know what mount that lens was originally made for. I recommend either taking the lens to a camera store or calling Quantaray to see if they can look up the mount using the serial number.
just want to know how to read the serial number of canon body
