Question about Jensen Iso-Max Stereo Line Output Isolator 1 to 1 Ratio Car Audio Amplifier
Loss of reception in 2002 ford focus factory radio fm
I have a 2002 ford focus, it has factory am/fm cd stereo in it. All of a sudden it looses the fm reception, staticy. It has fm and fm 1 an 2, have tried both and it does the same thing. Any ideas. Thanks Phil
  • 9 more comments
  • aib35 Mar 27, 2008
    Have similar problem but in a '02 Fiesta. Receives MW fine but no FM - aerial was checked last time it was in for a service, any other possibilities?
  • triggs Mar 28, 2008
    My radio on my 2002 Ford Focus will not get a reception from am or fm. I have checked the antenna connection and it was secure! My cassette does work! How do I know if I need a new radio or do something with the antenna?
  • bren200 Jun 05, 2008
    I have a 2001 ford focus ztec and can not get fm reception. can get am fine but fm went a couple of months ago. any ideas?
  • Anonymous Jun 09, 2008
    I have the same issue, no reception only once in a blue moon?? A mechanic told me that it's a common issue in this type of car.
  • Anonymous Jun 24, 2008
    I recently started getting poor reception with my 2002 Focus. I went on a trip, came back to town, and after about 10 minutes of driving, if I am lucky, my radio reception becomes full of static. What could be causing this?
  • Anonymous Jan 17, 2009
    Same as the others my 2002 focus Zetec factory titted
    radio as up FM although Am and cd are fine.It was a gradual deteriation.but now its completely gone.
    On the positive side i`ve discovered some good new radio
    stations!
  • krlbowman Jan 24, 2009
    Yeah, I have no FM radio stations. I receive AM just fine and cd player works. I've had another problem with my car where it wouldn't start and I've had to jump it a few times. It seems like this may have been the cause. Also after reading around on a few websites about this problem I found out that other people were having the same problem either right after working on their car or getting it serviced.
    Possible that the head unit shorted out and it's some kind of electrical problem because I've checked all my antenna connections and they are good.
  • fordfukus Feb 01, 2009
    I have the same problem with the radio in my 2002 Ford Focus as most others on here. The CD player works fine but the AM/FM radio stations are full of static or do nothing at all. I am lucky I guess because I do get one AM station and it is my favorite sports station that I listen to all the time.  My wife however wants her FM. I got the tools to remove the radio so I could check the antenna, but the connection is fine.   I'm ready to go to the junkyard and just get another radio.
  • fish-hunt Feb 25, 2009
    I lost the entire fm and Am. AM has a distinct buzz. Went to the junkyard and got a drop in factory replacement and it worked. It definitely isn't the aerial, but has something to do with the radio itself.
    Mine worked until it warmed up. Cold Canadian days paid off.
  • 9lancer Mar 04, 2009
    The problem is exactly the same. How do you remove the aerial unit from the roof??
  • ezgulamu Mar 23, 2009
    We have the same problem with our ford focus. After a few minutes, the fm turns to static, tunes in and out for a few minutes until it is completely gone. AM works just fine. I changed the antenna. I believe this is a problem with the radio itself.
Common fault but as others have suggested, check aerial plug. It does fall out, speed humps vibration,cause it to come out of it's socket.If not this, try a seperate aerial such as a piece of wire or a small screw driver blade in the hole. Press search and see if radio finds a station and locks on.If it does then you know you have an aerial problem and your radio unit is ok. Sadly, if no luck and no result then the only answer is to relpace the unit as it is not servicable.These can be found at some car breakers but take your car and make sure that you buy a tried and tested unit with its pin No. Typical costs are £30 with casette and £70 for cd player.
However because there are so many different types of socket and plug arrangments on these units and they all look alike , don't be tempted to part with any cash until you have got the correct one that fits your car and it works. If does and you have its pin, it will have to be entered to make it work and you have made a written note of it in your Ford hand book , then pay the man. Good luck From been there and have the tee shirt. J.R. Note. Halfords do a fitted alternative replacement for around £150 if no luck and you are prepared to spend that kund of money.
Posted on Feb 05, 2009
More than likely the antenna cable has come loose from the back of the unit. Head to Walmart and get a removal tool, pull the radio, and resecure it.
Posted on Mar 12, 2008
Take it back to the ford dealer and tell them we all know they are aware of the problem and we as a group will be seeking compensation.lets form an on-line petition any IT people please organise one and i will publicise this using the media if we can get enough support.
Johng188@yahoo.com
Posted on Feb 06, 2009
SOURCE:
I am getting an error read on my CD player. The CD Disc CD player (original) to my 2003 Experdition will not release CDs. The CD player which is an automatic feed was force fed a CD by a minor child. The...
The unit can be removed but disassembly will be required to remove the OFFENDING CD. Even at that, the player mechanism may have been damaged so that CDs simply cannot be played at all
Jan 28, 2013 | OEM 2002-2004 Ford Focus Factory AM/FM...
Remove a 2004 focus stereo and replaced it with a new stereo
purchase the following: ford radio removal tools installation kit wiring harness the included instructions will make it a simple process.
May 19, 2010 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Fm radio doesn't tune
check that the antenna is plugged into the back of the unit or look under your fender and make sure it is plugged in there as well or use manual search instead of autosearch
Jun 26, 2009 | 2004 Ford Focus
Bad radio reception
Problem: Radio Reception is bad to non-existant. AM is usually worse than FM.
Reason: Antenna connector has come loose, and needs to be reconnected. This happens when a passenger pushes the carpet toward the firewall and disconnects the plug.
Affected Model Years: 1997, 1998, 1999, 2000, 2001, 2002, 2003
Permanent Fix:
1. First check to make sure the antenna at the back of the radio has not come loose.
2. Remove the plastic cover on the front passenger door threshold held in place by three pressure clips.
3. Peel back the carpet on the front seat passenger floor.
4. Locate the coax antenna cable running along the side.
5. Reconnect the two pieces of antenna that have come loose.
6. Roll the carpet back, and re-install the threshold cover.
Nov 01, 2008 | Kenwood KDC-119 CD Player
JVC detachable face with auxillary input
You may have a bad antenna or antenna cable.
FM signals are measured in microvolts and are easily influenced by poor antennas or a mashed antenna cable.
Aug 12, 2008 | JVC AM FM CD DET FACE CAR STEREO
Car Audio & Video Logo
8,814 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
