The problem started in the cleaning mode. The oven started beeping and showing an f8 code. The cancel button stops the beeping but it resumes after a few minutes. Tried shutting off the breaker but the beeping resumes when the breaker is turned on. Tried hitting both cancel buttons simultaneously per the online manual but no luck. Can't get the oven to work without beeping.
Hello there
First i would unplug it for 1 hr to allow the oven internal reset to reset it'self than plug it back in and see what happens but if this doesent help than here is a listing of the code and what it means
F8
Lock motor relay watchdog is ative when it should be off
Microprocessor
checking the operation of the EDC lock relay after self
clean is selected, relay failed. Replace EDC.
Lock switches
Check or Replace
component
There is a problem with the lock for one of the doors do they both close all the way or does one hit the latch. could be bent linkage or bad switch on lock or the control board has a bad relay on it.i need a model # to help any ferther
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
Oven Control Beeps
and Displays an "F"
Error Code
Electronic control has detected a fault condition. Push CANCEL pad to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
number, push the CANCEL pad and contact an authorized servicer.
