What is the solution or How can i repair this?
That error message from diagnostics indicates you answered no to the Video test displaying correctly. Exactly what are the symptoms of the system?
Cust laptop is shutting down within 10 mins and when run the PSA then the Error 2000-0334 is coming up...
My laptop have aproblem error code 0334,how i can solved this problem?
SOURCE: how can i solve a problem with dell laptop that an
Hi There,
Your error code is listed near the bottom of this Dell Support page (link below) with a link you can click on for the Fix for your problem.
Take care,
TheSelkie
SOURCE: my laptop got error 2000-0334
Hi there!
Error 2000-0334 is related to an error with the video. I suggest you uninstall and reinstall the video adapter.
Hope this helps.
SOURCE: error Code 0334. Msg : Error
Msg : Error Code 2000-0334
Msg : Video - user reported the patterns were not displayed
SOURCE: 0334
That message indicates that you did not input during the diagnostic that you could see the test. If the system is running normally, then the error can be ignored.
SOURCE: error code 0334 msg 2000-0334
Looks like you have a dell desktop PC and the error is with the graphic card, remove the card and try it on the integrated display , re seat the card and check if error reoccurs replace card!
