I have an Amana 90 Air Comand Gas furnace/AC, it's 4 or 5 years old and has hardly been used...the problem is that it won't turn on...I hear the thermostat click...the unit has electric and gas...the red led light isn't on...thus no codes...
Hi, If you are talking about an led light at the furnace, and it is blank, it should have a 3 to 5 amp fuse that plugs into the board. Pull it and check to see if the metal element is blown or burnt. If so, replace it. If you are talking about some other red light, please let me know. It sounds as though you have lost the 24 volt control voltage, so see if it has a fuse on the board. Keep me posted.
Shastalaker7
Thanks for your answer
I had checked the 3 amp fuse and it was good. There is electric to the board...if I understand right, the led should be lit at all times...the board looks like it did when it was new...I wonder if the a resistor is out or the capacitor are burned out...
