I get video feed but no audio feed. My cd player and ipod work fine. The picture is on for the tv and dvd but no sound. What button do I push to activate the sound through the HDMI cables?
OMG - this happened to me today I see the TV but can't hear anything -I play a DVD - but hear the TV , can't hear the DVD at all - I hear music and CD's just find .......anyone please helpOMG - this happened to me today I see the TV but can't hear anything -I play a DVD - but hear the TV , can't hear the DVD at all - I hear music and CD's just find .......anyone please help
You can't post conmments that contain an email address.
I have the same problem. Good picture with no sound at all. I have a LG DVX583KH and LG TV LM7200. I connected the DVD player to TV via HDMI cable, I have a clear picture but no sound. I try to hook up the DVD to other TV and it works both sound and picture. Please help
Hello, I am sorry about your issue. Have you tried the other HDMI ports on the receiver. Please check the cable from the receiver to the TV. Thank you, Onkyo USA
Hook your Xbox to tv via HDMI, then hook TV to reciever through digital optical or composite cables. If you try to get your picture through receiver first, you may get picture and sound but, sound may be delayed and picture might not be the best. Bettter to run through tv first then provide sound to receiver.
Also the test tone is working OK (Setup / Speaker Setup / Test Tone)? Have you used automatic speaker setup with the supplied YPAO microphone? For HDMI, you need to configure the receiver to "take" out the audio from HDMI. Go to Setup / Function Setup / HDMI / Audio and select "Amp" to route the audio to receiver, or "Amp+TV" for audio to go both to receiver and to TV. You can also check in Options Menu / Signal Info that receiver has recongnized the sound and what format it thinks it is in.
Regarding the problem with the sound on your DVD player, I would suggest you to make sure the audio cables (red and white) are connected properly to the TV and player.
Also, try using a different set of cables since those ones might not be working and this is why you are not getting audio. On the Memorex remote you will find a mute button, make sure it is not activated.
Check HDMI Sound settings: Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV). Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Optical carries only 5.1 sound, no video. HDMI carries both video and sound. If your receiver doesn't have HDMI, check your TV for optical output. You can go BluRay to TV via HDMI, then TV to receiver via optical.
If you don't have optical out on your tv, you're going to need either a receiver with HDMI or a BluRay player with component output (blue, green, red).
