I have a Bissell ProHeat Carpet Cleaner -- but no manual...once I have filled the tank and turned on the machine, what is the procedure to follow for drag and drop? do I run the carpet cleaner like the vacuum? When do I push the yellow lever to release the water solution?
I am never sure of the proper motion of running the machine across the carpet to properly clean. What's the correct steps to follow?
Problem resolved by contacting a local retailer who provided instructions.
Pour more water on carpet till the detergent removed. You can hire the professional cleaning company athttp://www.carpetcleaning.irish/
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
