Its not my lamp because I have a picture. The standby switch blinks 3 times which means something but cant find my manual. Can someone please help? ThanksIts not my lamp because I have a picture. The standby switch blinks 3 times which means something but cant find my manual. Can someone please help? Thanks
You can't post conmments that contain an email address.
My daughter crystal 24 in tv/freeview/dvd is also coming up four years old ans stopped working too. Wont power up at all. Wont work with remote. Please can you help..
I'm not a service tech, but, I do have a copy of the service manual. It says the TV has a self diagnostics and according to the chart, 4 flashes indicates a backlight failure.
there seems to be a possibility that your ballast might defective.. i recommend you replace it. It might not have enough voltage to keep up with the new lamp
i have the same problem on mine, my tv is only just 12 months old, in the last 4 weeks it had 2 new blocks put in as the tv was blue, it costing £700 each (under guarante for 3 years thank god) then lastnight the tv made a big bang then switched it self off and the sand by botton is now flashing red then green, i have to leave it 30 mins before i switch it on again then only last 10 mins before it does the same thing again, got sony coming out again to day to fix it, had it with this tv now hate it !!!!!
Its the BULB people! You need to change it every 3 to 5 years! I have had my sony 55" for 6 years... I had Best Buy come out 3 years ago, changed the bulb... it worked fine. Just started flasshing and shut its self off and back on again. Time for another bulb.
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
