The channel name is frozen at the top of the screen and at the bottom the word "Mono" is also frozen, that is they both remain on the screen. I cannot get onto another channel. If I go to analogue, it is fine, but if I return to digital, the whole picture is then frozen. If I switch the set off and then back on, I return to the moving picture in digital mode but with the channel name and mono frozen again and again unable to change channel.
Huckfinn: would you be willing to do chat to debug this problem? If not you are going to need to share all the information you possibly can about all your equipment hooked up to this TV.Huckfinn: would you be willing to do chat to debug this problem? If not you are going to need to share all the information you possibly can about all your equipment hooked up to this TV.
You can't post conmments that contain an email address.
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote
select the Reset option. Using the right arrow button at this point
will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
pl.see whether the other channels were locked inadvertently 2)if you have set top box remove the connection and connect the cable to antenna slot if you could change channels set top box is defective other wise tuner problem
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Sharp has had a few problems with their audio boards, not finding any bulletins on this model, but a few complaining about low audio on amazon reviews section. If using an antenna you will experience some channels with low audio. If using cable you should get good sound on all channels..
the 9.1 and 9.2 are digital channels and sharp does display them for at least a few seconds when you switch to that channel. Check all your setting in the audio to Stereo never SAP. To options for you are get a cable box, first check in the back and see if there is another coax in, if there are two try both rescanning after connecting.
GD lk
Eric
The TV set itself will probably have a button that is marked either "Video," "Input" "Source" or "TV/VCR" - I would need to have your exact television model # to be sure. Make sure the cable box is on. Press the Video/Input/Source/TV/VCR etc button and see if your cable picture reappears on one of the source channels. If your television is connected to the cable box with a standard coaxial cable, then Ch.3 or Ch. 4 would be the right choice. If you have a digital cable box, however, the cable is probably going to be on an auxillary channel. If you give me the exact model # of your TV, and the type of wires that run from your cable box to your TV, I can give you more precise instructions. Good luck!
TV SETTING 1. Press the MENU button. 2. Use or button to select the TV setting menu, then press or button. 3. Use or button to select the Channel no. setting and use the or button to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts). 4. Use or button to select the Tuning mode and use the or button. 5. Use or button to select the Auto tune and press or button to confirm the selection. The unit will immediately search through all possible TV channels and store those channels with signals in memory. After this is complete, the unit will switch to the first channel found. 6. To exit the MAIN MENU and return to the normal screen, press the EXIT button. Note : In DVD mode, this option is not available. Remarks: 1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode. 2. Tuning mode : Air or Cable mode are available. 3. Auto tune : Searches for usable stations and stores them in memory. 4. Skip : ON - Skip weak channels. OFF - No channel skip. 5. Fine tune : The frequency changes to allow fine tuning. 6. AFC : Auto frequency control. 7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP). 21 TV SETUP MTS (Multi-channel Television Sound) SETTING This feature allows reception of sound other than the main audio for the program. 1. Press the MENU button. 2. Use or button to select the TV setting menu, then press or button. 3. Use or button to select MTS menu, and press or button to select the options (Mono, Stereo, SAP) 4. To exit the MAIN MENU and return to the normal screen, press the EXIT button on remote control. Note: • MTS only operates while in TV mode. • The SAP (Secondary Audio Programs) feature allows a TV station to broadcast other information, which could be audio in another language. RESTORE SETTING If you reset the TV to the factory settings, all your present settings on picture & sound will be erased and replaced by the factory’s default settings. However, picture setting in PC mode and parental setting will not be erased.
setup of bridge mono mode:-1-turn your amplifier off.2-connect input wiring to channel(1) input--3-connect speaker across positive outputs terminals-do not use negative terminal when amplifier is operating in bridge mono mode.4-turn down (fully counter clockwise)of channel (2).
Well the default is to obtain the channels signal. most channels over the world their audio output signal is mono. Rare tvs have the ability to save indivisual channel to their memmoty. Read the tv prospectus!!!
