Hi my sony trinitron tv was flicking onto standby and then on again for 15 mins .now it will not come on and still flicking red and then green standby light any help please
model no kd-32dx15ou and it constantl blinks red green red green.thank you for getting back to memodel no kd-32dx15ou and it constantl blinks red green red green.thank you for getting back to me
have you tried unplugging it and plug it in after a couple of hours or overnight.have you tried unplugging it and plug it in after a couple of hours or overnight.
You can't post conmments that contain an email address.
It sounds that there is some short circuit with its SCL-SDA rail, at its main digital circuit board. It will be best to contact any service technician, as troubleshooting the main board is a skilled work.
In time as the Sony Trinitron ages it begins to have power issues. While this can be true of most tube televisions it's the rate and severity at which this happens to Trinitrons that makes it particularly of note. Many Trinitron owners have complained of the Trinitron set turning itself off randomly and frequently. Some sets have failed to stay on for longer than a few minutes at a time. Eventually some sets will not turn on at all. These problems grow more severe with age.
Check the power cable running from the Sony Trinitron 32. Make sure the cable is completely inserted into the power connection on the rear of the TV as well as the local power outlet.
Disconnect the power cable from the electrical outlet, then plug it into a different connection. It is possible to electrical outlet has died, forcing you to obtain a power current from a different source.
Check the cable connection running from the cable/satellite receiver or VCR. If the TV is on but no picture is on the screen, the problem is most likely due to a connection issue.
Power off the cable/satellite receiver, then press the "Video" button on the remote control to switch the Trinitron 32 to the video input signal. Turn on the cable/satellite receiver and the programming now loads onto the television screen.
hi i am in ethiopia,electronics equipment service man & I got many & many repair tips let us share call [email protected]
MY NAME IS BINIYAM DANIEL = +251912871449
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
there is no pause just constant thanks
