We are using Polycom VSX7000 unit. And we are facing problem in making or receiving calls to the unit.
We are making calls through IP, the unit has been NATed & a public IP is given.
In firewall settings page of the VSX7000 we have option called H323 Compatible. If we enable this option we are able to receive the incoming calls but not able to make outgoing calls.
If we disable this option we are able to make outgoing calls & we are not able receive the incoming calls.
Please suggest what to do for this problem.
SOURCE: Bad Video Quality in Sorenson VP-200 to PolyCom ViewStationEx Calls and vice-versa
If connected to a Cisco Switch, make sure the EX is not set to Auto for Speed or Duplex.
SOURCE: I have a polycom viewstation FX and appear to have
How many lines (circuits) do you have going to your system? Is it possible they are out of order? Give me your ISDN numbers and I'll try to connect to you. Where are you located? My e-mail address is [email protected]
SOURCE: Polycom soundstation 2 not showing
The link below may help you on resolving the issue. This is a PDF file for user guide:
http://www.orficn.net/Verizon%20Website/Phone
%20Manuals/audio_conferencing_polycom_soundstation2_user_manual.pdf
Just click it. Please let me know if this help you or not so that I will proceed to the other solution.
