Hi Follow the below procedures. How to install and start the Apache or httpd service under Linux
by Milind
Q. How do I install and start the Apache or httpd web server under Fedora core or Cent OS?
A. Apache HTTP Server is a free software/open source web server for Unix-like systems and other oses.
Apache features configurable error messages, DBMS-based authentication databases, and content negotiation. It is also supported by several graphical user interfaces (GUIs) which permit easier, more intuitive configuration of the server.
Use rpm command to install Apache under Linux. You can also use up2date or yum command to install the same. Task: Install Apache/httpd under Fedroa Core/Cent OS Linux
Type the following command if you are using Fedora or Cent OS Linux:
# yum install httpd Now, start the Apache/httpd # chkconfig httpd on # /etc/init.d/httpd start Task: Install Apache/httpd under Red Hat Enterprise Linux
Type the following command # up2date httpd Start the Apache/httpd # chkconfig httpd on # /etc/init.d/httpd start Task: Debian Linux httpd/Apache installation
Use apt-get command: # apt-get install apache2 # /etc/init.d/apache2 start Task: Verify that port 80 is open
# netstat -tulpn | grep :80
You can also install httpd from CDROM with rpm command: # rpm -ivh httpd* Configuration
Your server is started but you need to configure and use Apache as per your requirement. /etc/httpd/conf/httpd.conf (RHEL/Cent OS/Fedora Core Linux) or /etc/apache2/httpd.conf (Debian / Ubuntu Linux) configuration file. Use text editor such as vi to edit file. This file is very well documented or read official Apache configuration documentation for more information.
hi, this is a known problem in windows. The problem occurs when some process tries to execute the instructions which need admin credentials.
Right click on the JRE installation file, select "Run as" and provide details for Administrator (u might be the admin so provide yours, m assuming that you are administrator) and follow the installation procedure.
As i understand you receive an error when you run the installed program.
Please uninstall the complete downloaded software and reboot the PC. Then download the latest Java JRE (Java Runtime Environment (JRE) 6 Update 7) to run all Java programs from the link given below, http://java.sun.com/javase/downloads/index.jsp
Once you have installed the Java JRE, again install the program and test if it works.
