EPoX EP-8RDA3I Pro Motherboard Logo
Posted on Jan 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ACPI error message
I have a Epox EP-8rda3i Pro Socket A motherboard, was trying to install WinXP Pro from CD, keep getting error message: acpi error, I removed all my pci cards and only installed my ati video card. Still getting acpi error, can anyone help? Thanks Rob C.
  • rcrozier Feb 03, 2008
    Other issues appeared with the Epox Mobo I had to buy something else. I wanted to use most if not all of my pci cards with the new board, purchased a board by PC Chips M848A V5.0, Socket 462 /ATX. Everything works fine, except when I reinstalled winxp all the programs I want to install XP says "not a valid win32 program". I just want to reinstall MS Office, Adobe Photoshop etc, I don't have any win32 programs. Can someone help me solve this problem? Thanks in advance.
Devocap
Level 2:
Sergeant:
  • Expert 201 Answers
  • Posted on Jan 29, 2008
Devocap
Expert
Level 2:
Sergeant:
Answers
201
Questions
0
Helped
109025
Points
548
Hey there rcrozier, your solution is to disable ACPI in the BIOS. To do so, follow these steps. 1/ When set up is loading, a blue screen will appear asking if you have RAID devices, indicating pressing F6. Instead press and hold F7. This should prevent ACPI from installing. Alternately at the blue screen mentioned above, press F5 and hold. It should advance eventually to a new screen prompting you to press F2. Keep holding F5. It will give you another screen telling you it cannot recognize your pc type. It gives you two choices: standard pc or other. Choose standard pc. resulting in ACPI not being installed. Unfortunately the other result of this ACPI not being installed is that your power management will be reduced. Overclocking is not advised. Hope this helps. Good Luck!
  • Devocap
    Devocap Feb 05, 2008
    Hey there rcrozier, what I think you are indicating is the windows system trying to convince you not to install programs which they have not approved, or created themselves. The option to continue anyway should be presented to you with the message you were referring to earlier. Just continue anyway and all should be well. Good Luck!
I cant find drivers for my motherboard
You can download the drivers for your motherboard from this WEB site.
http://www.file-drivers.com/motherboards/epox/ep-8rda3i.html
Manual EPoX EP-8RDA3I Motherboard
http://www.epox.com/downloads.asp
download here
i hope this helpful
thank you for using fixya
Looking for site to download for free driver for my EPOX ep-8rda3i motherboard
cnet download.com,major geeks,tucows,open you might find something there
1helpful
On EP-8RDA3I ,I have code C1 and after two long beeps an kind of siren.This is happening even if I replaced everything excepting CPU.Thanks.
This is the problem of RAM in your motherboard, if you have already changed the RAM then clean your RAM socket in motherboard then insert the RAM.
Regards
Ashly
1helpful
1helpful
Epox EP 8RDA3I
Hello tenkist:
Many error codes in mother boards are similar.
Saying that, you need to get to the maker of the board, and find the information from them.
Sending them an email under support, will most likely solve what you need.
Invalid win32 program
this might be at the first look a problem of the softwere you are using...maybe your windows cd is damaged and it doesnt install properly..try to instal another version fisrt of all..and after check the main board drivers..
anyway..nice board you heva there..
No sound
Try updating your motherboard driver from this link:
http://www.driverstock.com/Epox-EP-8RDA3I-Pro-driver-download/26-36-6640/index.html
Hope it helps!
Top EPoX Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
