Support for the Sansa c200 series is on next site:
http://kb.sandisk.com/app/answers/detail/a_id/4487/session/L3NpZC92dFJ3cUpRag%3D%3D/sno/0#c200
These are the differences of the Sansa version 1 or 2:
Sansa c200 version 1 only supports MicroSD. The version 1 series firmware starts with V1.
Sansa c200 version 2 supports MicroSDHC and audible format (AA). The version 2 series firmware starts with V3.
NOTE: The firmware is not interchangeable.
How to check firmware ? From the main menu on the player select Settings Mode > System Info.
You can delete voice recordings this way:
1. In playback mode, press the Submenu button.
2. Select Delete.
1. Connect your device to the PC.
2. Select Open device to view files using Windows Explorer on initial connection.
3. Locate the folder where your files are stored.
4. Click to select the files you want deleted and delete the files.
When files don't show up you'll have to switch from MTP to MSC mode on the player. How to switch to MSC mode, see:
http://kb.sandisk.com/app/answers/detail/a_id/61
Before disconnecting in MSC mode always go through the safely remove hardware icon in the right corner below of the computer screen !
Need more help ? Just post a comment.
The easiest way is to connect to your computer via a usb cable. Click on the local disc "E: or whatever yours is and do it on line. Remember to use the safe disconnection procedure.
