Adding a wired computer or device to the network.
If you router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
If you are adding a desktop or any other device to the router which will always be connected to the router with the Ethernet cable, then in this case you don't need to do anything.
You can just connect the Ethernet cable between the router and the computer and it should work.
If you are not able to go online even when it is connected properly then check IP address of the computer.
Adding a wireless computer or device to the network.
If you want to add a new wireless device ( laptop or any other wireless device) to the network, then you should know all the wireless settings of the router. What wireless settings do you need to know ?
You should know the wireless network name ( SSID ), wireless channel and the wireless security password
( network key ). Once you get all the wireless settings of the router , you will need to connect to the wireless network on the computer. when you try to connect to the network , you will see your wireless network in the list. You just need to select your network and connect to it. If it is secured then you will need to enter the network key and you will be able to go online.
To check the wireless settings of the router , you will need to access the router set up page. On the set up page you will find all the wireless settings of the router.
click Here for step by step instructions
You may need to enable wireless connection in laptop.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
I have tried everything all of these steps, my WPA key, the IP address (auto and manual) and the router settings. But how come other pc with XP and Vista OS are connecting on both cable and wireless. By the way my new pc is using Intel WiFi Link 5100AGN and Broadcom Netlink (TM) adapters. The windows troubleshooting is suggesting to upgrade the firmware of this router but the last version I found for this router was 2005. Is ther any other updated firmware for this router?
