Freezers Logo
Posted on Dec 30, 2009
Westinghouse fridge freezer alarms keep going off
Westinghouse virtuoso fridge freezer alarms keep going off for no apparent reason. No doors are open but the temperature seems to be dropping in the freezer section. I can't find the manual. How do I fix?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3554
Points
Try a different web site, where are the solutions on this one????? Great site..... not
Anonymous
Level 1:
New Friend:
  • Posted on Jan 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3554
Points
Hi
|We have the same problem too. We have not been able to resolve it eiher other than to turn the fridge off for 1/2 hour but the beeps return after about a day or so.
The freezer alarm won't go off.
Possibly a problem with one of the components in the automatic defrost system in the freezer then.. this is the only reason why the alarm would keep sounding. Perhaps some of the moisture from the defrost has gotten in and damaged the electricals somehow. It might be worth it to store your freezer contents elsewhere and completely defrost the freezer and then heat the inside cabinet up with a hair dryer or something similar. This will dry out the cabinet and the electrical components. Once the freezer has warmed up let it stand for as long as possible with the doors open so that it reaches room temperature and then close the doors and switch back on. If this doesn't work you probably need a service engineer visit.
I have a Westinghouse virtuoso, and for some reason the ice crusher just comes on and off as it pleases. As you could imagine the noise is very annoying. Could anyone please help??
your cooling system is damaged which harmful to your compressor,you must be changed your cooling system as soon as possible.
Mar 22, 2013 • Freezers
2helpful
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 • Freezers
2helpful
Zanussi fridge freezer alarm keeps sounding
If the refrigerator and freezer are both working properly. Then the only problem would be the alarm, It's either the placement of the alarm thermometer or the alarm thermometer is stuck closed.
Mar 15, 2010 • Freezers
2answers
2answers
Whirlpool fridge freezer alarm s20D RSB33AG-B
Hi, you have a common problem with your control boards; there is a cheap fix if you can use a soldering iron or you can have your modules repaired.
Let me know
bb
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
1helpful
Freezer door of electrlux freezer keeps coming
Try cleaning along seal and seal itself. If it does not work get new seal. The seal do go bad after a while.. If under warranty call dealer you purchased from for them to replace.
Jul 06, 2009 • Freezers
Fridge freezer door alarm continuously beeping
make sure gasket is sealing also make sure light is going out.
Jul 17, 2008 • Freezers
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
